Here is a quick example playing with some Pufferfish stuff (components in green) Maybe it helps.
Thanks Michael!
It still very cool but still don’t know how to control the diameter of the shapes + it need it to be more as a loft or a smooth surface, and this give you those steps or layers, which I still think are very cool for a bracelet but not quite what I am looking for.
Diameter is defined by circle component. Looking at your image it looks like you are sanding it smooth so wouldn’t you need the steps to cut out and glue, then sand?
I am sanding it just to give it some finishing. But it was actually made in a CNC, so the surface was very smooth. I think that this option is perfect for making it wit a laser cuter and then sanding down that steps. But I am not making it in a laser cuter I’m making it in a CNC, so if the result is smooth, I don’t have to work that much on it.
I can make it in 2 ways. Or I make two parts (half and half) glue it and sand it. Or just CNC both sides using a thicker material. I want to try using the thicker material
In that case you can disregard tweening. And always avoid booleans like union when possible, they are heavy operations.
PrudeSolid.gh (16.4 KB)
I’ll take your advice and I think that using this plug-in will be a solution. But I will still leave this open as the result that I am looking for is different, I am looking for more sharp and define edges rather than bubble/ ish. Which I still think are very cool and will definitely use it for something else, but not for this specific project.
Ok in that case bring the tweens back and switch the loft option (O input) to loose. Then the number of tweens (in pink) with define the sharpness. The planametric sharpness can be defined by the Prude Curves bulge option.
PrudeSolidTight.gh (22.1 KB)
I definitely have to play a bit more around with it I still think that this is a very cool plug-in. I have to go now and I will leave this blog open as the last time I asked something so many people came up with different solutions and approaches, from where I learn so much, as I am newbie in grasshopper and I want to learn. I can actually make exactly what I want in Rhino with no probs, I am just trying to understand and adopt the mindset of designing with grasshopper. So I prefer to see how other people can come with other solutions. Thank you very much for your help Michael!
Aris - thanks for posting your squircle solution. I used it to make this shape which I am printing now.
You probably know this already but just in case, Your remove end cluster you can just use cull index with index as negative 1. I see why you would want the shortcut tho
I have a lot of small clusters like this for one click solutions to usual operations
e.g half number / double number/ negative and positive values etc.
For me it declutters the canvas and saves a lot of time in the long run…
Totally understandable, Just wanted to mention it because often people don’t know about the -1 index trick
