I would like to ask if there is a solution for a poly-surface from points in Rhino like in the image shows below;
use the delaunay mesh component from grasshopper,
even with no experience thats easy.
after that use MeshToNURB or toNurb whatever version of rhino you have.
Grasshopper isn’t absolutely necessary, the Rhino command MeshPatch should do more or less the same thing.
interesting, that did not seem to work for version 5 not even with the dashed version, trying the wip it worked… i assume its because v6 is able to produce ngons? in that case i certainly would skip the grasshopper idea and make a makro which converts the points straight into a polysurface.
No, I think the command was just improved for V6…
MeshPatch is the way. Thank you.
