just wondered if it was possible to write sentence and then polar array it onto an object
Um the short answer is ‘yes?’
okay ,so do I write it in text or do I use the 3d text and then space as I need it in the sentace?
You would probably use the TextObject command and create solids.
thanks I’ll give it a go .
Hello- my guess is PolarArray
is not what you are after here - more likely a Flow
operation from a line to a circle or arc.
no what I’m after is to be able to write a sentence then take the sentence and then polar array the sentence ,and the maybe project it onto a surface ,similar to writing round the edge of a coin
… that definitely sounds like Flow
If you polar array a sentence, you get the identical sentence repeated, for example like this:
If you want to wrap the sentence around like a coin, you flow it, e.g. like this:
I wasn’t familiar with that quote so I just looked it up - sounds an interesting play!
yes thanks that is what I was trying to do .
