Points in Layout Space
This could be on purpose but it feels like a little bug. When editing text, leaders, or lines in layout space the points come on and stay on. I have to use the command pointsoff a lot. It’s kinda annoying.
Screen Shot 2023-12-21 at 09.53.15
I’ve noticed this too, recently :sweat_smile:
Hi Chris - in Settings > Mouse page has the setting to turn on points on selection the first bit is expected but I see that if I double-click to edit text, thinhs can go south.
Does this corretly describe what you see?
RH-79297 Double-click to edit text
Yes. That sounds normal. The issue I’m having is that the points stay on after deselecting the object.
Hi Chris -
That issue is on the list as RH-73252 Editing text make it not selectable
For the time being, you’ll have to use the Esc key to turn those off.
RH-73252 is fixed in Rhino 8 Service Release 4 Release Candidate
