Points as result
How can a divide a surface in equal peaces, and the on each crossing adding a point…
Only the points are the final gaol…
https://1drv.ms/f/s!Avk4VSnUidoxgiYjuAMVCKOSR5hK
Hi Blueship - try ExtractWireframe then Intersect the resulting curves - does that get you the right thing?
Yes :slight_smile: Thanks Pascal thanks :beers: :+1:
Maybe a strange question but is it also possible to give some weight on the dots?
With weight I mean a sort of volume / dimension.
Example if I want to try replace all dots by small cubes…
Hi Blueship - in V6/WIP, if you turn the points into a point cloud you can use testPointCloudStyle to set some parameters for their display.
Thank you Pascal, …if there is no other way to achieve this result, I need to wait for a newer version of the software personally …ore search for an other solution maybe!?
Hi blueship,
You could modify the display mode and change how points/pointclouds are drawn:
HTH
-Willem
