I am facing an issue with the visibilty of the points and lines that I have created using the grasshopper script. This problem occurs when I compile my grasshopper script into a cluter. But when I open the cluster everything is visible.
You aren’t actually outputting the points that you wish to display as a cluster output so the cluster, as designed, does not preview nodes disconnected from outputs.
