Points and control polygon are being printed
Another issue is printable selection!
so I guess I need to add a _PointsOff precommend for CTRL+P
Thank you @mary
To clarify the above, If I have an object selected with a _PointsOn, It will be always printed, and my expectations is that I don’t want to see that, sometimes I forget to use the _PointsOff before printing so I end up seeing my selection box and the control points in my PDFs.
@tay.othman Got it.
Now I understand.
I logged RH-79362 Control-points-on-single-selected-Objects-Print:
This YT is for public view, and you can check status by viewing.
When there is a fix tested and in a service release you will be notified here in this thread.
As a workaround, a “window select” on 2 or more objects and then the control points or rectangle highlight are not printed.
  • However, a windows select on one object, will still have the issue.
  • Printing to the Rhino PDF seems to be able to ignore the control points in the output.
  • But not so with other PDF writers and physical printers, are not so sophisticated.
All of these details , are include in the YT.
Thanks for your help.
Sincerely,
Mary Ann Fugier
This got me too… Only realized it after a large plan has been printed :frowning:
RH-79362 is fixed in Rhino 8 Service Release 3 Release Candidate
