Import file from photogrammetry prog photomodeler, group them for manageability.
run PointDeviation, turn on points filter and drag cursor selection over points, nothing happens.
need to ctrl select each point separately impractical given quantity.
If they are grouped they should just all select together with a pick- with a window selection you’ll need to window around the entire group, or hold ctrl-Shift to select within the group.
