I’m recently started modeling some stuff with Pointcloud data. I attached pointloud as a worksession. I was wondering if it is possible if there is an option to check and uncheck visibility of pointcloud/worksession in a particular view, just like clipping plane functionality?
Hello - one way is to make a display mode that ignores point clouds -
And then set the view to use that mode.
Hi Pascal,
Thanks for the reply. Yes this is a way to do it. After watching this option, I also figure out that I can also do exactly this from display tab. So thanks again.
Yet, it’s not per view option. It is same as turning worksession off or layer off. How 'bout making it per view option? That would be awesome. In fact it would be awesome to have all display tab per view based.
