I am trying to organize the centroids of the panels to either be within the BREP or outside of it. However, it comes up with a reading of all false which I didn’t think was true. Attached is my file. Any help would be appreciated. Thanks
Thanks. I am new to this. I have looked online for the answer into how to change my single surface into a closed BREP but I could not figure it out.
Also, I am unsure of what internalizing data means. I tried right clicking on my surface (BREP) and clicking “internalize data” and it unplugged a connection from my previous component. Is this reaction typical?
Your definition will reference some Rhino geometry no doubt. Right click on any components which reference Rhino geometry and click ‘internalise data’ and save the GH file. This will cut the link between RH & GH so that your GH file can stand alone without needing a RH file. This is the simplest way to share scripts.
Since your surface is flat, you might also consider point in curve.
Note that if you want to include points that are on the edge, you will need to set the “>” component to “>=”.
