I was wondering if there is some quick way to get point rotation. I’m asking as when a point is rotated using gumball the gumball remembers its state - ofc it can be that gumball remember state per doc object id - but maybe there is some option to read transform of it or can be achieved only implementing custom doc object doing from the ground up kinda “pivot” point?
Hi @D-W,
Sounds like you want this?
https://mcneel.myjetbrains.com/youtrack/issue/RH-58174
If a Rhino object has been manipulated by Rhino’s gumball, and the gumball is not in its default position, then the object’s repositioned gumball frame is returned.
– Dale
Bullseye! Though i guess i won’t be able to cheat like that and implementing CustomPoint for “pivot” point will be enough. I was looking for sth like point normal in a pointclouditem it would be enough for my purpose. Besides you know v7 ETA is not in my scope
Anyway thanks for throwing this in maybe ill find some quick and dirty way with use of Gumball Plane I would be really grateful if we could move the IO topic a bit as I guess i hit a dead end there.
