Hello all,
I have seen some points being displayed as solid dots (solid circle will be in the properties, I believe).
when I go to the properties I have no such option.
my question is, is there such an option in the properties and is this possible to display the points as solid dots? also it would be ideal for the dots to have their unique thickness. if you are asking what use this will be. I do alot setting out drawings for construction and dots are frequently used. below is an attache image illustrating my topic hope is clear.
I look forward to your replies and thank you for your help.
