Hi all,
how can i convert the intersection event to a point object ?
Rhino.Geometry.Intersect.Intersection.CurveSelf(Curve,0.001)
or better how can i use the result ?
Rhino.Geometry.Intersect.IntersectionEvent
Thanks for Tips
Hi all,
Thanks for Tips
Rhino.Geometry.Intersect.IntersectionEvent.PointA
You might also want to check if the curve is overlapped with itself
@flokart - the online RhinoCommon doc has a lot of info:
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_Intersect_IntersectionEvent.htm
Thanks for the small example.
Tried it and the Intersectionpoint poped out.
events = Rhino.Geometry.Intersect.Intersection.CurveSelf(Curve,0.001)
if len(events) > 0 :
a = events[0].PointA
Yes RhinoCommon gives me all options for IntersectionEvents but i didnt know how to call the properties because no small example is given.
Now i know it.
Thanks both of you
