When I am running the Point deviation tool from a surface to a mesh and I modify the control points of the patch, the hair display is not updated, even though is set to “Automatically apply changes”.
Am I doing something wrong or is a bug?
As far as I can see, this point deviation diagnosis is not meant to be updated while you are modifying the input data. Is that correct?
In that case, couldn’t be nice to have this real-time updating capability? Because every time you want to correct the deviation, you need to remove the old analysis and reselect the inputs again, and is very time-consuming and frustrating…
Thanks in advance.
It should work, this is what I get:
I don’t know why but my Rhino is not able to do that.
I posted a video here below:
You need to select the surface you are going to edit last
thanks!
Hi @Gijs
Is it possible to add not only color representation but numbers as dots?
As an option to the dialog box. I think it’s about v8 only?
It will help during MoveUVN edit.
Thanks.
