I have a surface as you see in the picture, I want to create lines at the middle of each profile. as you see in the picture i want to have those Red lines on my surface indeed i want to have the grids between this rows and then in another software i should give them a steel profile.
Any one can help me ? if you know a way to create the hole of surface with this kind of division in grasshopper it would be fine. and if you want the rhino file to help me i will do it.
Hello -it appears you have a 3d object with 3d curves - I am trying to understand how these curves or edges were made, of you made them in Rhino, and if so, why you cannot do the same thing for the mid curves.
thanks for replying. good question . because the reference model was a mesh and i just could pick points on its edges and i couldn’t find a way to do this for the red curves i showed in the image above. if I could put some point exactly on the surface maybe i could draw the red ones.
