I have an issue similar to the one below. If a block contains a point cloud it will cover the geometry in the Rhino workspace when using a ray traced view port. I have numerous files with referenced blocks that all do the same thing. The solution to the previous issue only works if the point cloud is not part of a block.
Hi Chad - this should be fixed in the later service releases - what SR are you running - can you please post the output from the SystemInfo command in Rhino?
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti (NVidia) Memory: 8GB, Driver date: 4-25-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.79
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-25-2023
Driver Version: 31.0.15.3179
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
G:\Castaneda Engineering\software\Rhino 3D\Plug-ins\RATplus\Rhino\RATplus.rhp “Rhino.NET SDK” 0.0.0.0
C:\Program Files\RhinoDB\bin\RhinoDB.rhp “RhinoDB”
Hm, well now I am only getting black viewports in raytraced - something is busted - but a full render looks like what I expect
(later, in-house, sr however)
OK, I do see the problem now in the raytraced vp. If I tumble the view or go into BlockEdit, it sorts it out temporarily… weird, thanks for the report. RH-76108 Raytraced vp: Blocked point clouds in front
