The other day I updated to Version 8.11.24254.15001. Until now, I was able to bundle python libraries inside of the plugin project in the ScriptEditor. When a Python 3 command was run, it would unpack the libs into %appdata%\McNeel\Rhinoceros\packages\8.0\<PluginName>\<PluginVersion>\libs\<EnvironmentID>\library
. When rebuilding the plugin in the new version, the libs get unpacked to %appdata%\McNeel\Rhinoceros\packages\8.0\<PluginName>\<PluginVersion>\libs\<EnvironmentID>\library\library
. This is a problem because when the commands import library
, they now have to import library.library as library
The update also broke publishing if the .rhproj file is missing a “publishTarget” setting. It didn’t use to do this.
