PlugInManager lost
I use a lot Rhino to developp PlugIns. With the version 5 and 6 off Rhino it was possible to load plugins via the PlugInManager. With the version 7 I simply don’t have the PlugInManager. I go to :Tools->Options
and… nothing do you have any Idea how it is possible?
Hi Markus -
When you type Options on the command line, does the dialog box appear?
Also, please run the Rhino SystemInfo command and copy-paste here.
Hi Wim,
thank you a lot for your answer. The option’s dialog box appear.
Here I provide you the full Rhino SystemInfo
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Pack école Revente interdite, build 2021-08-10
License details: Cloud Zoo
Windows 10.0.18363 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-7-2021 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M1200 (NVidia) Memory: 4GB, Driver date: 7-3-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.40
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 8 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-3-2019
Driver Version: 26.21.14.3140
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
Hi Markus -
And, I suppose, there’s a Plug-Ins section on the left side? What happens when you click on that?
Apart from that:
I would think that this is the most likely culprit for any issues that you are experiencing. Is there any way that you can disable that?
The current final version is SR 10 but the SR 11 release candidate is also available.
These drivers probably could use an update.
The plugin manager user interface is implemented in the commands plugin which somehow must have gotten disabled on your system. Try dragging the commands.rhp from your installed rhino plugins directory and drop it onto rhino.
It wooorks
I don’t know why but updating the software worked. Thank you a lot
