Plugin to read document data
I want to build a plugin that will read document data saved by my plugin, post it to a form and be able to edit the fields. I have the following code that works in the original plugin, but fails in the new plugin. the EditDocumentData_Data Find() method calls
TryGetValue(documentSerialNumber, out EditDocumentData_Data data)
which returns data = null
//The data //
namespace EditDocumentData
    internal class EditDocumentData_Data
        // Our data major and minor version numbers
        private const int MAJOR = 1;
        private const int MINOR = 0;
        // The dictionary used to store key/value pairs
        private ArchivableDictionary m_dictionary;
        public EditDocumentData_Data()
            m_dictionary = new ArchivableDictionary();
       public string GetDocumentData(string Key, string Val)
            string res = "";
            m_dictionary.TryGetString(Val, out res);
            return res;
        public bool SetDocumentData(string Key, string Val)
            //Result result = new Result();
            bool result;
            result = m_dictionary.Set(Key, Val);
            return result;
        public void Write(BinaryArchiveWriter archive)
            // Write the version of our data
            archive.Write3dmChunkVersion(MAJOR, MINOR);
            // Write the dictionary
            archive.WriteDictionary(Dictionary);
        public void Read(BinaryArchiveReader archive)
            archive.Read3dmChunkVersion(out var major, out var minor);
            if (MAJOR == major && MINOR == minor)
                var dictionary = archive.ReadDictionary();
                if (null != dictionary && dictionary.Count > 0)
                    Dictionary = dictionary;
        #region Properties
        public ArchivableDictionary Dictionary
            get
                if (null == m_dictionary)
                return m_dictionary;
            set
                m_dictionary = value;
        public int Count
            get { return Dictionary.Count; }
        #endregion // Properties
//The DataTable//
    internal class EditDocumentData_DataTable : Dictionary<uint, EditDocumentData_Data>
        private static EditDocumentData_DataTable g_table;
        private EditDocumentData_DataTable()
        public static EditDocumentData_DataTable Instance
            get
                if (null == g_table)
                    g_table = new EditDocumentData_DataTable();
                return g_table;
        public EditDocumentData_Data Find(uint documentSerialNumber)
            if (TryGetValue(documentSerialNumber, out EditDocumentData_Data data))
                return data;
            else return null;
        public EditDocumentData_Data FindOrCreate(uint documentSerialNumber)
            if (!TryGetValue(documentSerialNumber, out EditDocumentData_Data data))
                data = new EditDocumentData_Data();
                Add(documentSerialNumber, data);
            return data;
Assigned to Developer category
