I am developing a Grasshopper plugin for timber joints.
I would like to ask if you can load the plugin on your computer by running attached example files after installation.
The reason to ask is because it I am doing C++ Interop and would like to know if it is properly working on windows and mac os.
Sadly, here on macOS (macOS 12.3, Rhino 7.18), there seem to be a few problems.
First, there is an issue with Apple security checking :
Not a very big deal, just had to click-right open each .dylib files from the library folder before reopening GH.
cross_end.gh, chevron_end.gh, and dataset_end.gh all had the same issue with input_get component. The component doesn’t throw any error message, but isn’t outputing anything.
closest_lines throws an error : Solution exception:joinery_solver_pinvoke.dylib assembly:<unknown assembly> type:<unknown type> member:(null).
Then of course, nothing can work, but I assume input_get wouldn’t manage to read the joinery_solver_net.Data either…
Once everything is authorized once, and Rhino is restarted, the example definition load fine and Gatekeeper never pops up again.
But then input_get is not able to read anything (at least not able to output what it reads). Without error message, it seems difficult to debug… It is a bit as if the component was able to compute everything it needs, but then it does not find where to output this.
