Hi, I had a random toolbar reset recently, and I had to reset them to the default, but now all of the tabs and toolbars for my plugins are not listed in the toolbars options?
How do I gain access to the toolbars for my plugins when they are not listed?
(the plugins still are loaded and operate normally)
Check the folder where the plugin lives… should be listed in the plugins properties in Options. There may be a tb file there you can drag and drop into Rhino.
Yes, old V4 TB files can be opened in V5 and then V5 then automatically writes an RUI file for use. The old TB file is not used after that.
However, some command names and command options changed between V4 and V5 so some of the imported command macros may not work.
You’ll need to test then and modify them as needed.
