Plugin properties
So I’ve been working on a plugin and wanted to change the circled logo. Is it possible to change it?
Hi @jari123,
The RhinoCommon class, which your plugin object inherits from, determines the text displayed in that form.
The possible plug-in types are as follows:
1.) Rhino.PlugIns.PlugIn - a general utility plug-in
2.) Rhino.PlugIns.DigitizerPlugIn - a 3-D digitizer plug-in
3.) Rhino.PlugIns.FileExportPlugIn - a file export plug-in
4.) Rhino.PlugIns.FileImportPlugIn - a file import plug-in
5.) Rhino.PlugIns.RenderPlugIn - a custom rendering plug-in
Note, if you change the class from which your plug-in class inherits from, you may be required to implement one or more virtual methods.
– Dale
Hi @dale,
Thanks for your answer.
