Plugin Heteroptera
i need to install a plug in Heteroptera , cause the file asks for it ;
we installed it , but shape gives this error msg…it says that the version 0.7.3.5 and 0.7.3.0 of Amin Bahrami is not supported yet and i need to install the 0.6.2.4
searched for the older version , but did not find it anywhere…
The latest versions of Heteroptero throw errors on the servers, therefore they are not yet supported. We will solve the problem in the near future. At the moment, please find the supported version here:
heteroptera_1.gha (1.1 MB)
You will need to manually add it to the components library:
  1. Right-click on the file > Properties > Check the “Unblock” checkbox and save
  2. Open Grasshopper > File > Special Folders > Components Folder
  3. Copy and Paste the .gha file in this folder
  4. Restart Rhino and Grasshopper
You should then be able to open the Grasshopper definition.
thank you for the info; unfortunately another error appears:
the plugin clipper component assembly version 0.3.3.0 can is not supported .
the maximum version currently supported is 0.3.3.0
can you help me out with this ?
It seems the error message you reported above is not the exact one that our servers are giving. It should tell you that the maximum version currently supported is 0.3.2.0, as you can also verify in the Backend section of your dashboard:
You can switch your version of Clipper using the PackageManager command, in the “Installed” section:
Select version 0.3.2.0 and restart Rhino.
