Plug-in, Error loading
Every time I start Rhino WIP I get this message:
plugin
after clicking on “Details” I can choose to never load this plug-in again, but that doesn’t work, the same error pops up again when I start Rhino WIP the next time.
Is there any way I can get rid of this?
You should be able to load-protect the plug-in.
I tried that, doesn’t work. It is really annoying.
Enabled or disabled load protection (right click on the plugin) doesn’t make a difference, always the same error message.
just using wip to check out new grasshopper features, atm. so not that important but still annoying.
Hi @hitenter,
Go to the Windows Registry Editor and navigate to the following path: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\7.0\Plug-ins
Go through all the weirdly named folders until you find one with a “Name” value of “CyclesForRhino”. Delete the whole folder.
Any luck?
-David
did that and after that i also deleted files and folders with the name “cycles” within “7.0”- works! no more annoying error message, thanks!
