Please update the sub-"open"-dialogs so it is easier to find files on dropbox
Hi, it is difficult to quickly locate locations like dropbox, onedrive and on custom links etc due to these old dialogboxes:
This has been an issue in V5 for many years too, so please see if you can update this prior to V6 release.
Hm - yeah - it looks like those are mostly if not all RDK dialogs. I’ll see if we can tune that up - thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-42840
Thanks, and another thing “Dropbox” is a place, not a directory on a drive… This is important to fix since this messes up working on different computers or sharing stuff with shared folders:
If I make files on one computer and go to render on another then the HDRI texture is “lost”:
It is a directory on a drive - in this case your “D” drive. It’s just a synced folder. I always try to make sure the drive (letter) where the folder resides is the same on all my computers…
You can also make the Dropbox folder a library… you would then see it in the dialog you show above.
–Mitch
Needless to say, but it is also a location that the system knows where is, and dropbox is an established provider so I think Rhino should check if a linked file is located on it. (Among others)
As an example this script lists the files in your dropbox top folder:
import glob, os
print os.path.expanduser('~/Dropbox')
os.chdir(os.path.expanduser('~/Dropbox'))
for file in glob.glob("*.*"):
    print(file)
Good idea.
That’s a problem for me too.
Would be great if there was a solution for this, but probably difficult.
