Please tell me how to connect the surfaces
I want to connect these surfaces as shown in the picture.
I would like to create a Networksrf command beautifully if possible. What should I do?
Can you share a model for us to work with?
Thank you for contacting me. I will upload the data.
chair_base.3dm (2.4 MB)
Make a simple revolve and extend arms in to it. Trim then Solid Blend edge Distance between rails.
Thank you for the demonstration.
→ Trim then Solid Blend edge Distance between rails.
Could you tell me more specifically? After overlaying and trimming the surfaces, I do not know how I did it.
Use the intersecting surfaces to trim away from each other. Then Surface Join and Solid Blend Link handles and distance between rails.
Thank you.
The surfaces are connected. However, the wire frame is not beautiful. Could you show me the data if you like it?
In the Solid Fillet edge Blend edge Command Line there’s an option for Rail type. Click on it and switch to Distance between rails. I could tell from your image you had rolling ball selected.
Just for the sake of variety then, I played a bit…
chair_base_PG.3dm (211.9 KB)
Or maybe this way:
chair.3dm (951.0 KB)
Thanks to everyone. I came up with a good way.
Please refer to how to write the line of my date. Projection and lineblend You can do it.
The surface is not clean because it uses a network surface.
But,It is recommended because the edge can be connected firmly.
Thank you very much.
脚ベース作りのための5本接合.3dm (1.8 MB)
