Dear Mcneel Team
Please add an option in Pref. to not show this instruction box when dragging. it has no use [one can learn the drag options in the help panel
in the example here, I’m trying to trace a curve but the CP in hidden behind this box. The box can’t be moved as it disappears once one stops dragging. it’s a UI element that works directly against the user.
Please look into it. remove it, or add an option to.
Hi John
I know that option. thats not what I’m asking.
please kindly see my initial post again.
it’s a specific thing about the drag box that appears when you drag. Command options dialog is fine.
Yes, I understand that.
If you switch back to Command options in the Sidebar, try dragging a control point and you’ll see the options there instead of in a floating dialog.
I’ll be honest, I do not want to raise your expectations.
I don’t see this command specific change ever getting enough support to make it a development priority.
Having the drag options show up in the Sidebar seem to work for most people.
that theme was created and lots of users use it. so you have that theme, it needs to work correctly, which it does for most part but this little things need fixing it’s very obvious.
Telling the user not to use that theme makes no sense
Please ask someone else to look at this.
thanks a lot
Akash
utter nonsens. you did not help that user at all. instead you are insinuating that the user has an inferior understanding of the application and suggesting something that completely changes the workflow of an otherwise very helpful floating dialog. i assume you have no understanding of that general function or are not using rhino professionally at all.
what a messed up attitude. one simple dialogue which is bothersome and you would not even consider it worth tracking.
I would also like to support @Akash here. I also use the floating command bar and this panel is very annoying, and doesn’t offer any advantages to advanced users, so an option to not show this would be very welcome. Thanks.
From a support point of view, adding this sort of control might be more confusing than not. I’m thinking along the lines of the “Never show this dialog again” in export options. Once a user has disabled the options dialog, how do they figure out how to enable them again?
Another possibility might be to make the dialog smarter (if Command options were shown in dialogs), and not show up in a location away from the control points, but still close enough to be visible.
you are seriously implying that somebody who switched it off might be to dumb to understand how to switch such a useless window back? lol
i remembered these simple options from day one of using them. no need at all to show that window. as @Akash said that is something which easily can befigured out without being reminded each time while being hindered working properly.
filing a wish tracker will take you 1 minute. and no i will not refrain from uttering my opinion that is what such a forum is for.
