Hi all,i do want to save,export a simple file (cabinet) in one of the following extension options:
.xml
.dbt
.xls
.xlsx
.csv
Only the csv is a native extension of rhino5 bot when i open the file in the program(cutting optimization)it does not reconize the dimensions of the elements of the cabinet.
Is there a way to make a better csv settings for export,or is there a plugin for rhino to go thru its export options with one of the extensions that i need?
Please help,i do thank you in advance,all the best.
Hi Ilie - CSV is for object properties (in Rhino) it does not export the geometry. I do not know of a format that we export by default that would - you could conceivably make a script that writes a csv formatted the way you need, or an xml.
What program are you trying to open the file in? Maybe someone here knows the best way to work with this program.
Hello,thx Pascal,yes a script it may be a solution bot i m not good to make that.
Stevebaer the program that i try to export is: Cutting Optimization.
Any help or ideea is welcomed.
Thank you.
