Please help me blend this surface section
Hello, I seem to be having problems with blending sections of my model, i just can’t get the zebras to line up, and after i try to join the 3 surfaces together it creates a very visible kink (third photo). Every surface is degree 5 single span and untrimed.
Thanks in advance for any help or suggestions, I have also uploaded the model below.
forum.3dm (966.4 KB)
The surface may be good enough. Most likely the render mesh setting for the Zebra analysis is too coarse. Your can quickly make it more detailed from the pop-up window of the Zebra analysis.
What @Rhino_Bulgaria says, and always attach a 3D file to your posts, so people don’t have to guess.
Hi, thanks for the reply, the Rihno file is attached between the second and third photo, if anyone wants to take a look. My zebra mesh seeting is set to the most polygons. Sholuld it be set differently or is the problem in the surface itself?
Hi, thanks for the reply. My zebra mesh seeting is set to the most polygons. Sholuld it be set differently or is the problem in the surface itself?
As @Rhino_Bulgaria mentioned, it’s your surfaces’ display mesh settings.
Thank you so much for the help, I was really starting to lose my mind
