Please help, How is this pattern created along a curve?
Coorgated
This is a way for straight line
example.gh (7.9 KB)
@anon39580149 Thank you! How can this script be modified so the wave length can be adjusted from the centers of the ribs?
Hi, you can use “divide by length” Since the wavelength is 4 times of the divide length,
so, by inputting a slider = wavelength, then divide it by 4, then it’s the “divide length”.
Tanik
Try this, you need Polyline chamfer & fillet component from Fennec addon
Fennec | Food4Rhino
chamfer.gh (13.0 KB)
@anon39580149 thank you very very Much, this is SO close to what I’m looking for how can this be modified to select a curve and Turn Corners?
Thanks again!
Here’s one type of overall curve path
I’ve modified the attached file, its almost there, but how do we keep the angles from being askew example 2.gh (67.0 KB)
Maybe this is a similar question
