Please help, I’m a newbie here. Not sure why the curve is not following the vector?
The result that I expected:
rotate curve.gh (5.8 KB)
You didn’t internalize geometry.
Hello, newbie.
You will have to right-click and “internalize” your geometries before posting you files.
The implied starting point for a vector rotation is the X-Axis, so a vector in the first quadrant will be a counterclockwise rotation.
rotate curve v.2.gh (6.8 KB)
Here’s the internalized data.
can you give me an example please. here is the internalized date
No, there is no internalized geometry.
should be updated now. with V.2 as suffix.
Got it now. There is no Rotate ‘F’ (From) input so it defaults to Z.
thank you so much, i just put a Y input, and it solve everything.
Thank you so much @Joseph_Oster …
