Please Explain
Please explain why this is considered a closed polysuface. It has a shell-shaped hole in it!
Closed.3dm (196.0 KB)
Hello - the render mesh is certainly confused - there may be a loop in the trim curve of the central shell shaped face - in any case, MergeAllFaces to clean up.
Thanks Pascal. However, when I merge all faces I lose the shell-shaped hole in the middle which I need to keep. Any other ideas?
Thanks,
Dennis
Hi Dennis, if you want the hole, ExtractSrf that central face.
