Hi there.
There is a bit of an irritation that “play animation” shows up in the undo/redo list. Some times it messes up with back stepping.
Especially if you wanted to adjust something a bit at a time and when you “undo” to move a point on the path curve, then play the animation again. The end results in not being able to redo.
-Colin
