Dear @DanielPiker ,
I am experimenting with your great tool Remesher/MeshMachine
. I found on github.com the C# script of remesher (MeshMachine/src/remesher.cs
), and tried to rewrite the C# script to python so I can add some customization and UI to it (I know little about C#).
I then add my own function to control the variation of edge length. (The original method is workable, but less intuitive/predictable/controllable from design perspective). The problem I now have is that the
remesher
procedure gets quite unstable. I constantly run into “Index Out of Range” errors for some plankton functions, especially for the P.Compact()
. It seems to be less prone to such errors when the edge length is uniform. And I found these errors to be in-deterministic. You don’t know how many iterations you can go until you hit the Exception.
I am not sure whether this is common behavior for the original Remesher
tool. The C# script I am referring to might not be the latest either.
I can share the python code as well if you can help look into it. It is basically a translation of the original c# script. It has quite a few dependencies ( non-essential procedures, like UI, etc) , so tweaks will be needed when tested on another computer.
Best regards,
Vincent
PS: Never mind. Seems that I messed with some of the original code. It is usable now, although not bug free.
I also find that the edge size of the original mesh should not be too much bigger than that of the targeted mesh. This will reduce errors.
