Plane is rotated for Projection
Guys,
I’m trying to work out if I can stop this or a better way of doing it. I have a rectangle I’ve created from 2 points. Ive added some planes at an offset to each corner by projecting the offset curve to a point on the outside curve.
Screen flanges.gh (12.6 KB)
I’ve then calculated a point perpendicular to the original rectangle and used Orient to align it to each plane. However it would appear that every 2nd plan is rotated 180 degrees, thus Pushing the orientated point to the opposite side
