rhino question.3dm (38.3 KB)
I’m creating a exoskeleton glass facade in the given curve. But after drawing the single line i offset the single and give thickness to extrude but when i offset the line went front n back. How to solve the error.
I’m not at all sure I understand the problem you’re trying to describe.
When you Extrude a line into a surface or extrusion object, Rhino tries to guess the direction to extrude. If Rhino guesses incorrectly, there is a Direction command line option so you can tell it the direction you want to go.
Actually i want to offset the lines which i have at distance of 0.3m trim the collision and then i need to extrude. @John_Brock
