Plane aligned box of 3D text
I am trying to get the bounding box of some 3d text that is not in world coordinates, but in a plane I specify.
Using .BoundingBox gives me world axis aligned.
I can’t use Box(Plane,GeometryBase) as the 3d text is not geometry?
I can’t extract corner points of the text to create the box myself.
Any help would be much appreciated.
Hi Hugh,
Let me know if this sample helps (or not):
https://github.com/dalefugier/SampleCsCommands/blob/master/SampleCsBoundingBox.cs
Hi Dave,
If I understand correctly the simple approach is to work everything out in world coordinates and then transform back to the plane I am interested in? I was hoping to avoid having to, but it won’t be too much of a chore to implement.
Thanks for the help.
