I’m trying to do the equivalent of PlanarSrf using RhinoCommon, and I’ve come across an issue.
So far I’m using Brep.CreatePatch() to do it, and it works - EXCEPT if the closed curve in question self intersects (like an inward loop).
The Patch result looks fine in Wireframe, but when I go to any other view I get a weird polygon of some sort that doesn’t fit the border I see in the Wireframe view.
If I extract the border from this failed Patch, and use PlanarSrf, the desired result appears.
How can I duplicate that result using Rhinocommon?
What happens in Rhino is that the curve is processed using Boolean operations. You can mimic that using the following code
protected Result RunCommand(RhinoDoc doc, RunMode mode)
ObjRef cRef;
Result res = RhinoGet.GetOneObject("crv", false, ObjectType.Curve, out cRef);
if (res != Result.Success)
return res;
Curve crv = cRef.Curve();
if (!crv.IsClosed)
RhinoApp.WriteLine("Curve is not closed");
return Result.Success;
var x = Intersection.CurveSelf(crv, doc.ModelAbsoluteTolerance);
if (x == null || x.Count == 0)
Brep[] noIntersect = Brep.CreatePlanarBreps(crv);
foreach (var p in noIntersect)
doc.Objects.AddBrep(p);
// the self-intersection parameters are stored in ParameterA and ParameterB
// this is where to split the curve.
Curve[] split = crv.Split(new[] {x[0].ParameterA, x[0].ParameterB});
// the split will probably not be exactly on the curve start or end, so
// look for one closed curve and join the rest.
if (split.Length != 2)
Curve closed = split.FirstOrDefault(t => t.IsClosed);
if (null == closed)
RhinoApp.WriteLine("No closed curve found after split at self-intersection.");
Curve[] other = Curve.JoinCurves(split.Except(new[] {closed}));
if (null == other || other.Length != 1 || !other[0].IsClosed)
RhinoApp.WriteLine("Unable to join other parts into one closed curve.");
split[0] = closed;
split[1] = other[0];
Brep[] planar = Brep.CreatePlanarBreps(new[] {split[0], split[1]});
if (null != planar)
foreach (Brep p in planar)
doc.Objects.Add(p);
