SelPlanar will select all visible/selectable planar surfaces and curves - so if an object selects, it is planar.
CheckPlanarity will check one object at a time and report planar or not on the command line.
you can use gumball as a quick “planar check” if you see a scale handle in the z, then the curve is not planar. you can force it planar by clicking the scale handle and entering 0 in the scale dialog box then enter, the curve will scale to 0 and be planar.
If there is no scale handle, then the curve is indeed planar.
