Planar ring help plz
i need help to make this object planar so i can cap it and make it a solid
CHUBZ RING.3dm (62.2 KB)
you have a gap on the edges
Hi @Joshua_MacGregor
Delete one half
Turn on control points for remaining half
Select relevant edge control points
Scale selected control points to 0 to make sure that they are planar
Move control points to 0
Mirror surface and join them
Run Cap command
HTH, Jakob
Jacob’s solution [and I think he could mark it as such] is simple / elegant. Also, for future FYI I do not believe that one could have used cap on two surfaces given their is not a gap etc. The join command 1st then >cap.
