Planar curve projected to slope surface sees more control points occur
V5
why is it that simple curves drawn with a minimum of control points sees more of those points occur, if that curve is projected to a planar slope surface ?
the curve will simply get scaled in one direction, does that need a load of extra control points to form it ?
The simple handle set is now complex and I wanted the simple set to work with.
see attached.
3 curves (there is a small S curve) projected from vertical planar to sloping planar surface.
upper S curve with 4 points becomes 15 !
lower S curve 4 becomes 6
4 becomes 6 in the other single bend curve.
Project three curves from vertical to slope extra contol points result.3dm (40.2 KB)
Cheers
Steve
I reproduced the result in V5 - planar curves projected onto a plane have additional control points which are not needed.
V6 and V7 do not add control points for planar curves projected onto a plane.
In V5 use Loose=Yes if projecting a planar curve onto a plane to avoid the additional control points.
