Plan viewport doesn't select everything
Hi!
When I make a selection with drag-right or drag-left, in plan view, not every curve is included in the selection. It seems that it’s the shorter/smaller curves that are not included (not allways short curves though), so I have to zoom in and add those to the selection, which is not very good a workflow.
I’m aware of the difference between the two selection functions, and I’m sure that all curves are within the marked area, and on the same Z plane as well.
Perspective view does not do this, and works like it should.
Both in v7 and v8.
Any solutions?
Thanks,
Mikkel
Hej Mikkel -
This sounds like a file-specific issue. Please provide both a 3dm that we can check and the output of the Rhino SystemInfo command.
Hi.
It accurs in every file I work in, and I recall that this was also an issue when i had Rhino 7.
A test file is attached.
But here the info:
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
- Secondary monitor attached to adapter port #2
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\men\AppData\Local\Programs\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\men\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.20.2.16251
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\ProgramData\Autodesk\forma-rhino\Rhino8\FormaRhino.rhp “FormaRhino” 0.7.1.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24254.15001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.11.24254.15001
Test file.3dm (438.6 KB)
Hej Mikkel -
Thanks for the file. If this happens in every file and multiple versions of Rhino, we’d have lots of reports about this issue. It’s looking more like a system-specific at this point.
When I window-select left-to-right everything in the top viewport, I get:
52 block instances, 235 curves, 37 texts added to selection.
When I do this in the perspective viewport (after zooming to extents), I get the same number of objects.
If you open the file that you attached here, and then immediately left-to-right window select from the top-left corner of the maximized viewport to the bottom right, do you get different numbers? If not, is there a specific workflow that makes this report different numbers?
A longshot, but when you disable the 3rd party plug-ins and restart Rhino, does the problem remain?
When I left-to-right select i get:
51 block instances, 215 curves, 37 texts added to selection.
Right-to-left gives me:
51 block instances, 215 curves, 25 texts added to selection.
A few objects less that in perspective:
52 block instances, 235 curves, 37 texts added to selection. (same as you)
After i did this…
I disabled all enabled plug-ins and the problem is solved…
So, should I just go through the list and seek out the one that causes trouble?
Yes. But you can probably limit that to those:
Wim,
I have tried disabling all of the plug-ins on the list and then bit by bit enabling, until I finally had them all checked again… Oddly (for me at least) the issue is gone. But all checkmarks should be the same as before. I can’t make sense of this.
I also tried enabling the ones you refer to, VRay, VisualArq etc., but no difference whether enabled or not.
It’s solved for now I guess, by having all of them reloaded. But i’ll let you know if this changes.
Thanks for now!
I notice your Nvidia driver is from 2023. Although it apparently has nothing to do with this issue, it probably wouldn’t hurt to update it.
Thanks, I’ll do that!
