My Planviews in VA are not Updating, its taking longer then 5 min. The data isnt super large but I got some blocks with high number of faces in them, like Couches. Please help. Thanks
Hi Jesse,
Check your Document Units Absolute tolerance. Values smaller than 1 or 0.1mm may cause a slow response in the generation of 2D plan and section views. Also, the fact there are high dense meshes or complex objects may explain that slowness.
Do the Rhino Make2D or ClippingDrawings take less time to generate these 2D drawings? you should get similar results. If you don’t and can share the model, I can investigate more about the reasons of this slow performance.
I changed the tolerance to 1 and sadly it didn’t solve the problem. Make 2D is slow but it works. Is there an email address I can send the file to? I would prefer that instead of posting the file here.
Sure: visualarq@asuni.com
