Plan generation problem
Hello!
Something is wrong with plan generation. My model has this organic roof that is not too complex (red on the image).
When I generate a plan there is a massive square in the middle although it’s not actually in the model.
I have exploded the drawing and the square comes up as the roof layer so it must be something with it although it works fine anywhere else. See the roof file bellow:Roof.3dm (2.6 MB)
Hello!
Thank you for reporting the error. We are working on it to solve it. In the meantime, you can use the “_Explode” command on this roof before generating the plan view; it looks like this the plan generation works fine.
Kind regards,
Alfonso
Great! Thank you very much! Good luck with solving the issue.
