Getting to know Notilus Piping: Piping and HVAC design in Rhino
Notilus Piping is a 3D piping and HVAC plugin for Rhino 7 and 8, used by yards and design offices to model every system on board on the same model as the hull and structure.
Draw a pipeline directly or convert existing lines into pipes with elbows and segments, drop in valves and fittings, and let the bill of materials, weights and spool drawings follow the model as the design changes.
Key features
- Draw pipelines or convert lines and polylines into pipes
- HVAC ducts, cable trays, and hoses modeled with the same tools
- Valves, flanges, reducers,and fittings that snap to pipe size and spec
- Equipment library with exact dimensions and inlet/outlet positions, all information in one place
- Automatic penetrations against the surrounding structure
- Live bill of materials, pipe and fluid weight with center of gravity
- Spool drawings with dimensions and component lists
From mega yachts, workboats and ships to small boats plumbed with hoses, it covers fuel, ballast, bilge, urea, seawater, and HVAC systems.
Notilus Piping works with Rhino 7 and 8 for Windows. A 15-day evaluation license is available.
