Pipe start
Hi Forum, when using pipe command, how does it decide which end it picks? Seems like you should be able to pick the end to begin. —-Mark
Hi @markintheozarks
It uses the curve direction. Use Dir to show and Flip to… well, flip it :slight_smile:
HTH, Jakob
Edit: If you have history turned on, you can flip the curve post-pipe command.
Thank you Jakob, I knew it was something I was missing.—-Mark
