_Pipe gives unexpected and incomplete results with simple curves.
The radius of the pipe is 0.1.
The only correct result is with a simple rectangle .
The same rectangle with one point moved vertically makes errors, interestingly not where the point was moved.
When it comes to curves it becomes .
2026-10-15_Pipe.3dm (325.7 KB)
Same result in V7, V8, V9.
Have you tried lowering the tolerance? (set it to 0.5, for example). Years ago, Pascal—I believe it was him—told me to do that.
Charles
October 16, 2026, 10:46am
3
No, I didn’t have that idea, up to now.
I increased the tolerance to 0.1 and voila, I get a result.
As a workaround kind of acceptable.
This can’t be the solution.
Especially as the wanted pipe radius is also 0.1.
Instead of fiddling with the tolerance I scaled the geometry, by 10 and then again by 10.
Which usually works quite often.
No luck.
@sfp Perhaps it has to do with the intersector?
In any case, I consider this as a bug that needs fixing.
dale
(Dale Fugier)
October 16, 2026, 4:48pm
4
Hi @Charles ,
I’ve logged a ticket so we can dig into this.
Thanks,
– Dale
dale
(Dale Fugier)
October 16, 2026, 5:31pm
5
@Charles ,
Any better?
2026-10-15_Pipe_Fix.3dm (531.8 KB)
– Dale
Dale Fugier:
Any better?
Sure!
How did you achieve the result?
dale
(Dale Fugier)
October 16, 2026, 6:13pm
7
Hi @Charles ,
With fixes to the command - you’ll see in Rhino 9.
– Dale
That’s wonderful news, great!
Unfortunately not for 9.0, but ok.
