Has anyone run into the issue that the Pipe command does not always result in a consistent pipe diameter?
See example file. When the input curve was closed, the pipe’s diameter varied. If even the curve was broken slightly, the pipe’s diameter was consistent.
Is it a bug or am I using an incorrect setting?
Thanks,
Matt
PipeNonConsistentDiameter.3dm (757.4 KB)
