Pipe - Diameter and Wall thickness
Hi
in regards to _Pipe command, with _Wall Thickness activated
Is there a way to have the 1. diameter being the outer diameter, and wall thickness determine the inner diameter ?
As it is now, the 1. diameter is the inner wall, and wall thickness yields the outer diameter.
But in the real world, commercial pipes is listed with the outer diameter, and the wall thickness.
ex 26.9 x 2.6 mm (standard cold rolled 3/4 inch galvanized water pipe)
Its is somewhat counterintuitive to have to get the calculator out every time I have to make a _Pipe command using industrial Steel pipe measurements. In this case the calculation for first diameter is 26.9 - (2x2.6) mm = 21.7 mm
So, my question is, is there a setting somewhere that I have overlooked, that makes 1. diameter the outer diameter ? If not, would you please include this feature in the future ?
Thanks !
Hans Henrik
ahhh… I just found the answer myself :slight_smile:
You just enter the wall thickness as a negative value !
Hej Hans Henrik -
That’s correct, yes.
If you want to do this with multiple curves at the same time, you’ll need to run Rhino 9
→ RH-86855 Pipe: Accepts a negative number for wall thickness
