Pipe command - last dimension
If I pipe something at 1/8" and select curves individually it repeats the same diameter for each command but if I select more than one object it defaults to 2mm.
I’m working within the small object millimetre template but I’m inputting imperial measurements for commands… It’s easier for me working within the metric template and converting things to feet and inches (I don’t work in imperial very often).
Kinda feels like it should default to 1/8" or the last used radius/diameter for anything I choose either single objects or multiples.
Andy
Thanks.
Buggified as:
https://mcneel.myjetbrains.com/youtrack/issue/RH-36404
